Ben Jordan Posted March 31, 2006 Share Posted March 31, 2006 When the brakes in the Wolf are cold or under low pressure it gives out one hell of a squeal. I think it is coming from the rear. Are they the same brake as a standard 110? Are their any standard problems causing this? Im probably going to have them off tonight ready for my Wales trip tomorrow. So any ideas would be help. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 31, 2006 Share Posted March 31, 2006 put a new set of pads in of a decent brand copperslip on the back of them easy job take approx 1hr start to finish Quote Link to comment Share on other sites More sharing options...
Ben Jordan Posted March 31, 2006 Author Share Posted March 31, 2006 My thoughts were Copper slip or new pads just wondered if there could be any other problems. Well it won't be getting any new pads tonight. I think there is plenty of meat on them. if there is then it's Copper slip time. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 31, 2006 Share Posted March 31, 2006 just let it develop after all it is a L/R and can go wrong at will... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 31, 2006 Share Posted March 31, 2006 TC may have got it, use decnet branded pads, and the copperslip... Also while yer in there : A warped disc (from getting overheated) is one other reason this can occur, ........ .....as can sticking calipers. Also when you remove the pads check to see the wear, are they both worn about the same ? ....is the inside or outside edges even or one more than the other ? Keep us advised ? nige Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 31, 2006 Share Posted March 31, 2006 My 90 with original Genuine pads and 100% good discs squeals like hell. Tried copperslip, no effect at all. Now I just live with it, even though it irritates the hell out of me Quote Link to comment Share on other sites More sharing options...
JST Posted March 31, 2006 Share Posted March 31, 2006 try washing them out, may be dust build up although doubt it in the weather we have been having recently. HS XD setup is std 110 rear brake setup. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 31, 2006 Share Posted March 31, 2006 Try oiling or greasing them. that'll stop the squeeling. Quote Link to comment Share on other sites More sharing options...
