northernchris Posted April 1, 2006 Share Posted April 1, 2006 Just changed the clutch AGAIN in the 90 the one i put in on thur/fri started slipping!!!! Anyway just thought i would show you all another use for a roll cage Chris Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 1, 2006 Share Posted April 1, 2006 You should get yourself an armchair, they don't have a clutch to wear out, no more problems Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2006 Share Posted April 1, 2006 Chris, pic needs to be rotated 90 degrees to correct way up, you can do this in photobucket, use the edit facility for the picture. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 1, 2006 Share Posted April 1, 2006 I thought that was the clever bit, turn the vehicle on its side to change the clutch Quote Link to comment Share on other sites More sharing options...
dollythelw Posted April 1, 2006 Share Posted April 1, 2006 did ya get it sorted in the end Chris? Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted April 1, 2006 Share Posted April 1, 2006 I thought that was the clever bit, turn the vehicle on its side to change the clutch In Northern Kenya there is a group of incredible drivers who run Gat (a leaf that is chewed by the locals for it's buzz) from Somalia and Ethiopia to Kenya. The leaves have to be delivered at market within 24 hours of harvest and in order to do so have to cross about 700 kms of dirt tracks. The "runners" use ancient LRs held together with pure inginuity and bush sense and the drivers can do the most incredible repairs in the middle of no where with very few tools - anyway rather than jack up or crawl under it is not uncommon to see the LR being reapired turned over on it's side so enabling quick and easy access. You got to see these guys to believe it. Adam Quote Link to comment Share on other sites More sharing options...
northernchris Posted April 1, 2006 Author Share Posted April 1, 2006 BOG I need an armchair after the week i have had!! JEZ All sorted, faulty cover in the end,i ended up just putting a Valeo in. Time for a beer and a fag in my armchair. Chris Quote Link to comment Share on other sites More sharing options...
Mark90 Posted April 2, 2006 Share Posted April 2, 2006 Just changed the clutch AGAIN in the 90 the one i put in on thur/fri started slipping!!!! Anyway just thought i would show you all another use for a roll cage When changing the gearbox in the Saluki in the middle of the desert we employed a similar technique with a ratchet strap around the internal cage, although we didn't have a winch to make lifting and lowering easier. Quote Link to comment Share on other sites More sharing options...
