Sunroof
Jamest535
My Disco 1 sunroofs rattle like buggery on anything but a perfectly smooth road. I've been over and over them and can't get them to stop. So I just keep them closed as it avoids breaking the seal I have created using grease to stop water leaking in when parked on an incline. I now just look at them as if they are emergency exits, and believe me, my missus had to use a sunroof as an emergency exit on one of our previous cars, so I don't rule it out.
  • 1 month later...
My Rear one does this also. found that the slider attached to the glass should have a plastic bush in it that then engages with a pin on the lifting mechanism. This is missing on one side of mine causing it to rattle.
I have no idea where to get a new one however.
HTH.
Pete.
