Hybrid_From_Hell Posted August 23, 2005 Share Posted August 23, 2005 Disconnect the AFM from the harness plug, and go for a drive. The system will go into a Full Fuel and full air mode, it will run rich, but if no different then its not the AFM Check all the harness earths, these are critical, INCLUDING the battery earth. Check fuel pressure. Swap for good known ECU Check / change Amp ion outside dizzy for known good one Check for air leaks in the various pipework, this is exatly the symptoms, and also do a engine compression test. Lastly go and buy some FORTE Engine Fuel injector cleaner, place the whole container in about 1/3 of a full tank, and run the tank through before filling up again. I have a diagnostic manaual somewhere for the 3.9 Hotwire, PM me you e-mail, but ONLY if your on BroadBand and I'll have a rummage. Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 24, 2005 Share Posted August 24, 2005 Manual sent.................... Lets us know which bit(s) it was ?? HTH Nige Quote Link to comment Share on other sites More sharing options...
Mean Green Posted August 24, 2005 Author Share Posted August 24, 2005 Thanks Nige. I will keep you updated. Quote Link to comment Share on other sites More sharing options...
Steve RR Posted August 24, 2005 Share Posted August 24, 2005 Thats it Greeny - your gettin it!! as your sparky and local RRR rep just happen to be me! Quote Link to comment Share on other sites More sharing options...
Mean Green Posted August 24, 2005 Author Share Posted August 24, 2005 Thats it Greeny - your gettin it!! as your sparky and local RRR rep just happen to be me! Oh aye.. really need to be nice to you don't I, or my garage leccy will never be finished. How did you get on with insurance.... any improvement on £5370! Quote Link to comment Share on other sites More sharing options...
Steve RR Posted August 24, 2005 Share Posted August 24, 2005 What is one DOUBLE socket not enough?? Nicole must be a very big risk as the best I can find is £1600, Diamond were even about £3000. so it looks like Karen will have to insure it for here for a few years but that is still £660 ish. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted August 24, 2005 Share Posted August 24, 2005 There you go Steve young drivers. You must remember being young once or have you always been old Quote Link to comment Share on other sites More sharing options...
Mean Green Posted August 24, 2005 Author Share Posted August 24, 2005 What is one DOUBLE socket not enough??Nicole must be a very big risk Yeah, thats fine. I will just stick these 2 three-way cube adapters in, with a 6 way bar on each. That will be fine Saying nothing Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted August 27, 2005 Share Posted August 27, 2005 I have a diagnostic manaual somewhere for the 3.9 Hotwire, PM me you e-mail, but ONLY if your on BroadBand and I'll have a rummage Hybrid from hell, is it possible to email me this manual also? I could put it on a website for all? Regards Roger Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted August 28, 2005 Share Posted August 28, 2005 That would be very handy, could you post a link if you manage it. Thanks Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted August 28, 2005 Share Posted August 28, 2005 Disconnect the AFM from the harness plug, and go for a drive.The system will go into a Full Fuel and full air mode, it will run rich, but if no different then its not the AFM Mine doesn't do that (3.9 Hotwire) - if you unplug the MAF meter it won't run on petrol at all. Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted August 28, 2005 Share Posted August 28, 2005 Mines starts and runs without the AFM but it idles as rough as a bears bum and wouldn't pull the skin of a cold rice pudding. A wise man once told me that without the AFM it goes into a default map based on TPS input. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 28, 2005 Share Posted August 28, 2005 PM me a e-mail adres and I'll ping you the manual / diaganostic, AFMs 3.5, .....you can't disconnect as the pump runs when the flaps open under air draw. 3.9s, ......goes to default of Max air and max fuel, ....tests the AFM .....and yes it will run as rough as a rough thing at a convention on roughness Nige Quote Link to comment Share on other sites More sharing options...
fisha Posted August 29, 2005 Share Posted August 29, 2005 PM me a e-mail adres and I'll ping you the manual / diaganostic, AFMs 3.5, .....you can't disconnect as the pump runs when the flaps open under air draw. 3.9s, ......goes to default of Max air and max fuel, ....tests the AFM .....and yes it will run as rough as a rough thing at a convention on roughness Nige A 3.9 will definietly run without the AFM plugged in. When following one thats like this, its a little smoky as you toddle along and its almost like an over-fuelling diesel would be when you plant the throttle, plumes of black smoke out the rear. Of course, this can easily be avoided if people remember to plug the airflow meter connector back onto the air flow meter itself after having swapping them out...... isn't that right Greg? Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted August 29, 2005 Share Posted August 29, 2005 Absolutely, I'd never forget to plug the AFM back in after I've been changing plugs, air filter etc and had moved it out of the way to make life easier. You honour. Quote Link to comment Share on other sites More sharing options...
Nick Posted August 29, 2005 Share Posted August 29, 2005 I wouldn't ever run the car without the AFM connected either. Not even by accident. Honest. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted August 31, 2005 Author Share Posted August 31, 2005 Of course, this can easily be avoided if people remember to plug the airflow meter connector back onto the air flow meter itself after having swapping them out...... isn't that right Greg? Ah, emm err... yes. In my quest to solve the problem I thought I would try it without AFM! It was not me that thought it was a connector for an injector emulator. Update... no joy yet. Tried everything in the test sheets with no joy. Gas is now installed and it runs even worse on gas than petrol. It has now become dangerous to drive.. stalls constantly (although I have become and expert at flicking into 'N', restarting engine, back into drive, while going round a roundabout with no PAS and in heavy traffic) and just cannot be relied on. Going into the garage today (the former owner) with instruction to find the fault or it will be getting cut up into 50p size pieces!!! It was his pride and joy and the stipulation on the sale was that I did not bobtail it or break it - so hopefully it will focus his mind on fixing the prob Quote Link to comment Share on other sites More sharing options...
Steve RR Posted September 1, 2005 Share Posted September 1, 2005 I already have my list of bits I need ready!! Quote Link to comment Share on other sites More sharing options...
Mean Green Posted September 1, 2005 Author Share Posted September 1, 2005 I already have my list of bits I need ready!! Ah yeah, But I have the car you are going to put them on Quote Link to comment Share on other sites More sharing options...
Steve RR Posted September 1, 2005 Share Posted September 1, 2005 Do you offer a fitting service as well? Did you get to Martin's with posh (pile of s.) then? We got a bit damp on the way home, really must get the roof back on Nic's 90. Quote Link to comment Share on other sites More sharing options...
fisha Posted September 1, 2005 Share Posted September 1, 2005 did it pass? Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted September 1, 2005 Share Posted September 1, 2005 Update... no joy yet. Tried everything in the test sheets with no joy. Gas is now installed and it runs even worse on gas than petrol. You would think it would have to be ignition related then Quote Link to comment Share on other sites More sharing options...
Steve RR Posted September 1, 2005 Share Posted September 1, 2005 did it pass? Yes no bother, but the steering is still heavy and varing in power, I think I might put all your dad's old box on now. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted September 1, 2005 Author Share Posted September 1, 2005 Do you offer a fitting service as well? Did you get to Martin's with posh (pile of s.) then? We got a bit damp on the way home, really must get the roof back on Nic's 90. Fitting service is available - cant guarentee it will be fitted to your standard tho! I dont tend to use cable ties Yes, the P.O.SH made it down the road - ran sweet as a nut all the way there! thankfully it started playing up just as I arrived , so he heard the problem 1st hand. Fingers crossed he fixes it ... or it is curtains for the 3.9 and I will keep Kev's 3.5! I was going to give you a call to let you know I was thinking of you in my nice dry rangie Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 2, 2005 Share Posted September 2, 2005 Yikes ! Not often that the test sheet I sent you fails, You did all the tests and everything checked out ? I have some other stuff I'll dig out, but just update as to position now and above ??? Nige PS where do you live ?? anywhere near me (Guildford) ? Quote Link to comment Share on other sites More sharing options...
