V8 Freak Posted September 8, 2009 Share Posted September 8, 2009 I need part numbers for 4.6 exhaust headers for the stainless 4.6 manifolds and the down pipes. Pictures if possible as well Ralph. Trying to figure out if I can blend the rear section of my stainless system with some new headers and downpipes.... Neil Quote Link to comment Share on other sites More sharing options...
western Posted September 8, 2009 Share Posted September 8, 2009 I'm not able to print anything at the moment, no ink in printer. Best I can do right now is manifold RH LKC102470 mainfold LH LKC102480 gasket ERR6733 Bolt 58mm ERR5094 Bolt 100mm ERR5096 Screw M6 x12mm FS106127L stud manifold to downpipes TE110051L M10 x 25mm Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted September 8, 2009 Author Share Posted September 8, 2009 U got part numbers for the downpipes as well Ralph ? (U gotta learn to do screen grabs matey.. Stops all that printing and scanning..) Thanks a bunch so far Ralph. Neil Quote Link to comment Share on other sites More sharing options...
western Posted September 8, 2009 Share Posted September 8, 2009 downpipes are WCD105370 I can't get my PC to do screen grabs, prbably cos I don't know how to. Quote Link to comment Share on other sites More sharing options...
darthdicky Posted September 9, 2009 Share Posted September 9, 2009 I can't get my PC to do screen grabs, prbably cos I don't know how to. You should have a button marked Print Screen (or Prt Scr or something similar) normally above the Insert, Delete, Home, End etc. keys. If on a laptop you might have to hold down the Fn button at the same time to get it to work. Press that and it takes a grab of the screen but does nothing with it. Next go to your normal photo editor - Paint is fine. Go Edit > Paste and it'll put it in the file. Save as a jpeg and you've got your screen grab in a file ready to upload to the forum. For added fanciness you can hold down the Alt key when you press Print Screen and it'll only grab the active window, so doesn't include anything else on your screen at the time. Any problems give me a PM and I'll try to help. Rich Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2009 Share Posted September 9, 2009 You should have a button marked Print Screen (or Prt Scr or something similar) normally above the Insert, Delete, Home, End etc. keys. If on a laptop you might have to hold down the Fn button at the same time to get it to work. Press that and it takes a grab of the screen but does nothing with it. Next go to your normal photo editor - Paint is fine. Go Edit > Paste and it'll put it in the file. Save as a jpeg and you've got your screen grab in a file ready to upload to the forum. For added fanciness you can hold down the Alt key when you press Print Screen and it'll only grab the active window, so doesn't include anything else on your screen at the time. Any problems give me a PM and I'll try to help. Rich Cheers DD, I'll have a play later. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted September 10, 2009 Author Share Posted September 10, 2009 As DD says or there are loads of free applications that will do screen grabs and save to a file for you all in one action.. Thanks for the numbers. Neil Quote Link to comment Share on other sites More sharing options...
