rather quick winch
dollythelw
got a file from a friend showing his winch working, thought it might be of interest, I know it doesnt have a warn sticker on it but it is kinda spritely - I dont have anywhere to host it
any ideas??
Cheers
Jez
oops forgot to mention its a wmv movie clip so you get to see it in real time
So what is it ?
Where is the tech ?
Tech?? - its a Robur pto with autospooler :) tech is wasnt even in the options pack with them, they just just do power,
I think he may be adding a fusion reactor to increase power even more at some stage,
It has (apparently) been clocked at a max of 60kph but it only has 80metres of cable (262 feet in old money) so its more of a short sprint B) Ive only seen them do a reel in a minute but thats hardly quick compared to the tweaked version
Roburs look like this if you are curious, selectable throughput PTO, autospooler, 3:1 ratio, 80metres of wire is the standard load - typical eastern european overkill, why use a nutcracker when you can lay waste with a howitzer?
Probably not a lot of use in uk type events but for slugging matches they are pretty impressive
gods winch looks as rough as that
pto driven by 3.0 ltr twin trubo supra engine with no rev limiter basic
pto eng the gear is matched to the high rev`s small diff that the winch drum is welded to
bloody fast 1 good blip of a thorttle and thats 30ft coverd and thats with a bumper of mud in front of it whinch men have been knocked down and lost fingers its twice as fast as the vid clip if not faster
as soon as i get the vid back i will post it
God's winch, Satan's winch by the sound of it :D
3.0 ltr twin turbo winch motor that is just #kin insane!!! :lol:
must be about 280-300bhp makes a 6hp XP look a bit sick :lol:
I gotta admit I like the engineering,
machined drum to ensure the cable lays on perfectly,
nice big brake,
bellows to keep the carp off the autospooler,
Throughput PTO
nice touches - Ive never seen attention to detail like that on a western winch, that one needs a coat of paint and a new bellows but at over 30 years old its not bad :)
just blagging another two for the woodshed to go with the Bigstars B)
how thick a cable was on gods winch? did the car do well even after maiming its crew?
what is a "throughput PTO"?
one shaft for power input, one shaft on the other end of the winch for powerout, so you can select to run the winch, or whatevers on the other end, or both at the same time - handy for chucking a dirty great compressor on the end :D
