Def TD5 clutch pedal
klint
Hi at all, i've 110 td5,the clutch pedal is hard as all Def, but is not very fluid, if you press it very quickly you feel but if you press it slowly to the end, I feel that is rough, as if he needed to be lubricated, and then, while i'm going in any gears, if I try to touch the pedal without pressing, apart from the play, feel the vibrations .. I was wondering if everything is normal and how can I fix it.
Thanks at all.
Sorry for my english i'm italian
Link to post
Archived
This topic is now archived and is closed to further replies.
