02GF74 Posted August 22, 2005 Share Posted August 22, 2005 Instead of using air to lock an ARB, would using hydraulic fluid work instead? Something like having a sprung handle on a brake cyclinder with the tubing connected to the locker instead of air line? This would avoid having to have an air compressor and activation would be instant should one forget to turn on the compressor? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 22, 2005 Share Posted August 22, 2005 Not too sure. Les. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted August 22, 2005 Share Posted August 22, 2005 Nah, the ARB seals wont take the pressure Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 22, 2005 Share Posted August 22, 2005 If you were to apply only limited (80-100PSI IIRC?) hydraulic pressure then it would work. Easier to make your own arrangements for a compressor if you are (like me) too tight to buy an ARB one. I agree, if one used a brake cylinder the pressure would be too great with only a tiny lever pressure. Chris Quote Link to comment Share on other sites More sharing options...
