Td4 Vacuum
Cyberfarmer
Hi to all!
Im trying to figure out what the route of each vacuum pipe go to and from. I took off the acoustic cover of the engine and found that there is a loose vacuum pipe with filter from the turbo side and the T-joint along the vacuum line from the reservoir has been blanked off by a screw. Also, are there vent pipes located behind the air cleaner assy just behind the mafam? I dont know if the two should be joined together but I just want to make sure I install everything right before costing me something big.
Thanks guys.
Here are the pix of the vacuum line:
1. I intentionally removed the vacuum hose to the EGR and blanked it off, got the idea from the forum and the effect was good.
2. When I opened the acoustic cover, I saw this filter attached to one of the vacuum hose from the turbo, there was no hose attached to the other end of the filter. I only attached a hose on the other end just recently.
(pic 1)
....and from the other side on the vacuum line, the T-Joint was blanked off. I only attached a hose just recently. (pic 2)
....what I did was to connect the hose from Pic 1 (filter end) to pic 2 (t-joint). Is this right? I noticed when I attached the two, I could hear the turbo spool better, the revs go up faster, 0-120km/h was faster but I couldn't pass the 120km/h mark, is there a speed limiter? Am I missing a vacuum line? Is this related to the valve depression limiter filter problem?
3. Lastly, I want to ask if these are breather pipes or vacuum lines?
