Mike Brownlie Posted September 20, 2009 Share Posted September 20, 2009 Where are the numbers on a defender ? I want to check everything ties up with the V5 as the previous owner has given me doubts about the authenticity of the vehicle.... I know there is the plate rivited in the engine bay, which is okay. But where else are the numbers ? Cheers Mike Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 20, 2009 Share Posted September 20, 2009 VIN should be stamped on the chassis somewhere around the steering box mountings on the outside face of the chassis (you may need a wire brush and/or take off undershield to see it properly), and also on a plate inside the windscreen though the latter is not hard to change. Engine number is on the engine only, and there are gearbox, transfer box and axle numbers you can check against the LR Traceability service on a vehicle of any age. Quote Link to comment Share on other sites More sharing options...
Mike Brownlie Posted September 20, 2009 Author Share Posted September 20, 2009 VIN should be stamped on the chassis somewhere around the steering box mountings on the outside face of the chassis (you may need a wire brush and/or take off undershield to see it properly), and also on a plate inside the windscreen though the latter is not hard to change. Engine number is on the engine only, and there are gearbox, transfer box and axle numbers you can check against the LR Traceability service on a vehicle of any age. thanks for your help, i will have to get the wire brush out i think im paranoid but you never know.... Quote Link to comment Share on other sites More sharing options...
Jurriaan Posted September 21, 2009 Share Posted September 21, 2009 Thanks to forum member Stobbie, the chassis number on an early One Ten should look like this: Don't know which model year Land Rover stopped using the British Leyland signs before and after the chassis number though. Quote Link to comment Share on other sites More sharing options...
western Posted September 21, 2009 Share Posted September 21, 2009 should start with SALL************* 17 digits in total Quote Link to comment Share on other sites More sharing options...
tychoS Posted September 21, 2009 Share Posted September 21, 2009 Thanks to forum member Stobbie, the chassis number on an early One Ten should look like this: Don't know which model year Land Rover stopped using the British Leyland signs before and after the chassis number though. My 90" from 1988 has the little symbols before & after the chassis number. Quote Link to comment Share on other sites More sharing options...
