Langers Posted April 3, 2006 Share Posted April 3, 2006 My Def 90 is suffering for a broken rear shock mounting bracket - it's the lower bracket that connects the shock absorber to the rear axle. It was previously holed (rust) and has now given away completely. Is it possible to buy / weald on a replacement bracket? It's been suggested that I consider replacing the whole rear axle as its slowly being eaten away. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 3, 2006 Share Posted April 3, 2006 My Def 90 is suffering for a broken rear shock mounting bracket - it's the lower bracket that connects the shock absorber to the rear axle. It was previously holed (rust) and has now given away completely. Is it possible to buy / weald on a replacement bracket? It's been suggested that I consider replacing the whole rear axle as its slowly being eaten away. I dont know what the part number is but at Woolston 4 x 4 they have the bottom brackets on the shelf. Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2006 Share Posted April 3, 2006 The part your after isn't available from lR as a seperate part, only as part of a new axle case. don't see why a replacement can't be welded on, just take care to get it in the correct place in all directions. Quote Link to comment Share on other sites More sharing options...
Langers Posted April 4, 2006 Author Share Posted April 4, 2006 I dont know what the part number is but at Woolston 4 x 4 they have the bottom brackets on the shelf. Thanks for this Phil - would you happen to have the contact details for Woolston 4x4? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 4, 2006 Share Posted April 4, 2006 Thanks for this Phil - would you happen to have the contact details for Woolston 4x4? Wolston Garage & Engineering Brook St Wolston Nr Coventry Warwickshire CV8 3HB Phone 024 7654 2209 Fux 024 7654 4924 Email: info@douglassmotors.co.uk Web: www.douglasmotors.co.uk Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2006 Share Posted April 4, 2006 website link doesn't work, Google says 'unable to display page' Quote Link to comment Share on other sites More sharing options...
Langers Posted April 5, 2006 Author Share Posted April 5, 2006 Wolston Garage & EngineeringBrook St Wolston Nr Coventry Warwickshire CV8 3HB Phone 024 7654 2209 Fux 024 7654 4924 Email: info@douglassmotors.co.uk Web: www.douglassmotors.co.uk Checked with Wolstons - unable to provide lower shock bracket seperately as the no longer have a contact at the manufacturers anymore but can supply a duel shock kit for £70ish which contains two brackets - I'm going to try a local blacksmith first to get some made up - thanks for your help. Quote Link to comment Share on other sites More sharing options...
