qball Posted September 27, 2009 Share Posted September 27, 2009 Hi, I need some information on how to remove a TD5(2005) fuel tank. I have removed the following; 1. 2 nuts at the rear bumper. 2. the rear anti roll bar. 3. Feeler hose at fuel cap side. 4. Fuel tank breather hose. After all the above being removed. The tank still wouldn't barge. Would like advice on what other stuff I need to remove. Appreciate any info. THanks Jack Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 27, 2009 Share Posted September 27, 2009 According to RAVE there should be 2 nuts holding the tank guard bracket in place, and also 2 bolts, not sure where exactly but I guess it is still attached by the bolts. I seem to remember there are some up from underneath and some in through the crossmember or something? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted September 28, 2009 Share Posted September 28, 2009 The tank is supported only by the metal tank guard - There are two bolts that bolt to the rear crossmember, then two bolts on each side of the tank guard that bolt to the chassis brackets. Drop the tank guard and with a bit of fiddling the tanks should pull down - you then need to disconnect the fuel lines and loom to the tank. The fuel lines clip in to place in the top of the pump unit - you need to press the ittle lugs in at either side of the clip and the pipe disconnects. Quote Link to comment Share on other sites More sharing options...
qball Posted September 28, 2009 Author Share Posted September 28, 2009 Hi Folks, Firstly thanks for chipping in EightPot and BogMonster. EightPot, I had removed those bolts and nuts that you mentoned. But the tank wouldn't barge at all. I have tried using crowbar to pry it clear of the chassis mount but it just wouldn't move. Would there be any more mountings that I have not remove? Any folks with pictorials from a Workshop manual would be helpful. thanks Qball Quote Link to comment Share on other sites More sharing options...
JST Posted September 28, 2009 Share Posted September 28, 2009 has the guard come off? or are you stuck with guard and tank in place? Mine took quite a bit of leverage to get off with the aforementioned crowbar. Quote Link to comment Share on other sites More sharing options...
qball Posted September 29, 2009 Author Share Posted September 29, 2009 HI JST, The guard and the tank is still pretty much in place. Had try the crow bar...and is still stuck there. I am now clueless what is actually stucked. rgds Jack Quote Link to comment Share on other sites More sharing options...
qball Posted October 1, 2009 Author Share Posted October 1, 2009 Hi.. Finally had yanked the fuel tank out with a crowbar and brute force. Thanks for chipping in on the advice. Thanks Jack Quote Link to comment Share on other sites More sharing options...
