benbenukuk Posted September 27, 2009 Share Posted September 27, 2009 Hello, My x-brake needs Adjusting as I can move my 90 forward and backwards with the handbrake on How do I do this? cheers. Ben Quote Link to comment Share on other sites More sharing options...
western Posted September 27, 2009 Share Posted September 27, 2009 lift the centre seat/cubby box & cover panel, with the vehicle on level ground,set the handbrake to the 3rd or 4th ratchet click, using IIRC 2x 19mm spanners adjust the X-brake adjuster nuts so the brake is locked on, release the brake & check the moving pad is just litghtly touching the disc & the vehicle moves without the disc/pads heating up, if all OK, tighten the locknuts & refit the cover panel/seat/cubbybox. fitting & adjustment info here Quote Link to comment Share on other sites More sharing options...
benbenukuk Posted September 28, 2009 Author Share Posted September 28, 2009 Cheers all sorted now Quote Link to comment Share on other sites More sharing options...
