sweety Posted September 30, 2009 Share Posted September 30, 2009 Hi guys, i could do with a bit of help please. Just picked up my 1st LR a nice D2 V8 auto & on the way home noticed that the hand brake,brake fluid light keeps flashing on & off. I will even come on if the door is shut hard when parked up. Checked the brake fluid level & it's at the top Only thing I can think of is a poss broken brake pad warning censor wire, anyone got any ideas. Many thanks Neil Quote Link to comment Share on other sites More sharing options...
saltyoldseadog Posted September 30, 2009 Share Posted September 30, 2009 Mine's a D1 so I don't know if the system is the same; but could it be the sensor in the top-up tank? What makes me suggest this is that the light comes on when you slam the door which might make the level in the header wobble and trigger the light. I'm not an engineer but just occasionally basic logic can work - especially with Land Rovers. Quote Link to comment Share on other sites More sharing options...
sweety Posted September 30, 2009 Author Share Posted September 30, 2009 Thanks had been wondering if it could be that or the hand brake switch, so will check the switch 1st (when I find how to get to it) & if not that i'll try unplugging the brake fluid level sensor to see if that does anything Quote Link to comment Share on other sites More sharing options...
Naks Posted October 1, 2009 Share Posted October 1, 2009 I had that issue on my previous Defender - it's the brake fluid level. Just top it off and it should go away. Quote Link to comment Share on other sites More sharing options...
teabag Posted October 1, 2009 Share Posted October 1, 2009 Only a few things to check, low fluid level, hand brake not releasing fully or switch sticking on and a brake pad worn down to the sensor wire if this is fitted to your disco. Quote Link to comment Share on other sites More sharing options...
sweety Posted October 2, 2009 Author Share Posted October 2, 2009 Right i've now tracked the prob down to the brake fluid level sensor due to when it's unplugged there is no flashing light Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2009 Share Posted October 2, 2009 if the cap looks like this, you can prise the disc off the top & check the contacts are intact & clean. the float has a ring contact & the cap body has 2 small studs which the wire terminals connect too, maybe one of these is loose & causing the poor contact. Quote Link to comment Share on other sites More sharing options...
