transporter44 Posted October 3, 2009 Share Posted October 3, 2009 Following on from previous radiator question, moving Disco 300tdi lump into 1998 110. Is the Disco brake drum a straight swap into a defender? Reason I ask is I have the disco drum on the ground & want to rebuild clean & put new pads in & if its a straight swap for the defender I can do all that & have it ready & waiting for when I put the disco transfer box in during the engine swap. Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 3, 2009 Share Posted October 3, 2009 did the hillbilly helpline not answer??? did the great oracle of knowledge (kev) fail in your quest?? afaik its only the way they operate thats different(early to late) and the cables may be different but not insurmountable..... Quote Link to comment Share on other sites More sharing options...
transporter44 Posted October 3, 2009 Author Share Posted October 3, 2009 Tanks Flatback. No wasn't on to HBHQ, saving a bigger question for Kev. I had a feeling there may have been a difference, & hoped it was something small, as it would be nice to rebuild something while I had time rather than having to wait until I had the 110 drum & transfer on the ground. Quote Link to comment Share on other sites More sharing options...
kkk2 Posted October 4, 2009 Share Posted October 4, 2009 Disco handbrake fits easy use the disco cable as well a little enlarging of the hole through the bulkhead is as much engineering as is needed. I will give you a shout later in the day Transporter K Quote Link to comment Share on other sites More sharing options...
flatback90 Posted October 5, 2009 Share Posted October 5, 2009 Tanks Flatback. No wasn't on to HBHQ, saving a bigger question for Kev. hope you will be very happy together! Quote Link to comment Share on other sites More sharing options...
