Posted
ive drove my new 200 tdi defender conversion for 4 to 5 miles and the tempature gauge dosent move. And the oil pressure light stays on but if i earth the i wire out the temp guage goes straight UP. HAS DOES THE OIL LIGHT GOES OUT its a bit confusing any ideas any one
Posted
Have you double checked the wiring? When I did my Defender 200TDi conversion, I was lucky as I used a 200TDi from a Defender so it was a simple change of plugs. The oil pressure is a simple switch. What happens when you earth that one?
Cheers
Peter
Posted
well when i earth the oil pressure cable the relay clicks and it goes out the same for the engine temp it goes right up mdoes this mean i got a bad earth on the engine any ideas
Posted
Have you got an earth strap/cable between the block and chassis?
Dave.
