Posted
Hi all
Ive got a series 1 trialler on rrc axles
v8 on a series 2a gearbox
Problem ive got with the clutch is that with just 1 pump of the pedal the slave cylinder does not push clutch release arm far enough to disengage clutch
If i pump it very quickly it pumps the slave out a bit at a time like a hydraulic jack + pushes realease arm far enough to disengage
Its the 2a slave clylinder which sits vertical on drivers side of the bellhousing with what looks like an original series 1 master cylinder
What ive been thinking is that the capacity in the master is too small to move the slave in just 1 push + when pumped quickly the master refills from reservior + pumps more fluid through + eventually pushing it right out
Is there anyone that can confirm this or has any ideas of how to get round this?
Anyone know the bore + length of the series 1 clutch master?
Cheers all
James
Posted
No air in there
I checked, double checked + then got a mate to triple check just to make sure it wasnt me having a funny day
Slave was originally leaking so that was replaced + theres no leaks at all from any where
once the slave is fully out it does stay there if i hold the pedal down
Also clutch is extremely heavy
All of these reasons are making me think that the master is no large enough
Will a rangie / discovery or even series 2 or 3 master bolt in?
The connecting rod isnt realy a worry as i could always modify one of them to fit
Cheers
James
Posted
For a start off the series 1 clutch was fully mechanical not hydraulic. As its now hydraulic then its been converted. Series clutch master is 3/4" bore and slave IIRC is 1" bore.
Posted
Did it ever work correctly?
I have the same set up on a Series 1 gearbox but I had to cut and shut the arm and bits to make it work.
Marc.
