Posted
Evening all...
I've got some major issues with my lights. The situation is as follows:
1. With the lights off, and reverse gear selected i get LH Indicator on full time, fog light on, reverse light on.
2. With lights off, indicating left i get LH Ind, HeadLights, Reverse light and fog light flashing.
3. With lights on, i get LH Indicator on full time, Fog light and reverse light on. Cant indicate left.
4. with lights off, fog light on i get as in no 3.
Groovy! good news is that whilst playing i got my interior light, clock, horn and full beam flash back! anyone with any ideas on what could be wrong? I've tried changing the hazard switch as i know that can cause problems but no change.
Also, i found a wire which was white with a purple stripe in the engine bay, not connected to anything but very much live. not good whenits bouncing around off the fuel filter.
Many thanks for any insight!
Posted
White and purple is the feed for the electric fuel pump, if fitted. It's fed from a relay in the fuse compartment. If you haven't got a fuel pump then put a bit of heatshrink over then end.
The other problems all sound like bad / broken earths at the lights end (behind the covers in the rear load compartment) or a serious set of crossed connections - sure you didn't disturb something else?
The headlights coming on in two is odd, as the only place that lot share a common path is the horn/main beam/flasher/indicator switch - I'd check that out to (they do break).
Posted
Thanks for the info, it turns out that when i lost my exhaust the hot gases melted a section of the loom that runs along the back of the crossmember. All replaced and works a treat.
