Posted
...............exiting through the rear crossmember cause exhaust fumes to be
drawn in through the rear when the canvas window is rolled up ?
Posted
It happens with a side exit pipe too...
Posted
With my standard exit pipe you still get a bit of exhaust sucked in when you lift off, even with the canvas rolled down.
This is made much worse if you open the windows- but goes away completely if you open the bulkhead vents :)
On LPG the smell is OK, and you dont smell like an old car when you get to where you are going... :ph34r:
