Posted
confirmed...
If the oil/grease is on the ball itself, it's the swivel seal that runs on the (should be) smooth surface of the swivel ball. see here
If your balls aren't rusty and If your balls ARE rusty
If just the wheel/tyre is oily it could be the hub seal, so see here - Hub seal replacement
It's easy to see which (out of the two above) is leaking, get under there..
