Retroanaconda Posted October 8, 2009 Posted October 8, 2009 Hello all, I have mounted my NATO hitch as per this link: http://www.retroanaconda.com/landrover/?p=52 Now, with a piece of 12mm steel behind there I very much doubt it is going to pull through, but I have noticed it's nigh-on impossible to do the bolts up properly as the crossmember is just crushing inwards. My question is, should there be crush tubes in there for the NATO hitch holes? Many thanks Quote
mike4444244 Posted October 8, 2009 Posted October 8, 2009 Yup there should be crush tubes or more likely a '#' shaped noughts and crosses grid inside, if you have a carp aftermarket xmember these wont be there and will lead to it distorting, also I think technically you are advised to fit the nato hitch with 2 sets of nuts... Mike Quote
TD5 power Posted October 8, 2009 Posted October 8, 2009 hi yes you definitely need crush tubes in there, have a look at les's write up here HTH matt Quote
Retroanaconda Posted October 8, 2009 Author Posted October 8, 2009 Bugger, this isn't the first issue that I've had with this crossmember. Damn cheapo previous owner ¬_¬ How do you mean two sets of nuts? The second set acting as locknuts? Quote
Retroanaconda Posted October 9, 2009 Author Posted October 9, 2009 Yeah, well that's what I've done. As for the crush tubes, well I'll have to try and get some added at some point. It'll have to do as it for now though. Thanks all. Quote
