yellowmitch Posted October 9, 2009 Posted October 9, 2009 Hi there. I have an a/c extended front panel and the slam panel relating to it for my 90 build. Can I easily fit this? what other brackets do I need? Thanks Alan Quote
simonb Posted October 9, 2009 Posted October 9, 2009 Hi there. I have an a/c extended front panel and the slam panel relating to it for my 90 build. Can I easily fit this? what other brackets do I need? Thanks Alan Yep will fit, I have one and it clears the full width intercooler better than the standard panel. Its chucking down with rain here so no pics, but the only extras required are a few strips approx 75mm long of 3mm ally that pick up on the wing fixing holes where the original panel fits and extends out to the new panel. In typical LR fashion, the factory just bolt through the panel to these strips. There is probably a proper part (at great expense) but its easy to make your own. Quote
yellowmitch Posted October 9, 2009 Author Posted October 9, 2009 thank you simon. That is helpful to know. Photos would be great if you get a chance to take some Quote
Happyoldgit Posted October 9, 2009 Posted October 9, 2009 They're an easy fit. The pukka LR way uses an additional couple of additional little brackets. Quote
