Posted
i ve turned the star wheel 180 degree and the diagrham 90 degrees fantastic change love it
smoke screw (under cover) turned 1.5 times nothing no smoke no change so i take it easya nd twist it 90 degrees at a time and i cant get it to smoke or anything. got to a point where could not get lock nut on so gave up and screwed it all the way back out.
whta have i done wrong and do i need to play with the screw on the out side of the body of the pump near the solnoid instead?
Posted
By "smoke screw", you mean the one on the diaphram cover? That is only for setting fueling when there is no boost. It will just help reduce turbo lag. It won't affect power above 1500 rpm. Look for smoke at 1000 rpm and full throttle.
Posted
just play with them all, just make records of what you do, and do them one at a time, i have fiddles with, the star wheel, the diaphragm, the smoke screw, the power screw (the one on the side wit the anti tamper collar round it, i think its the one your on about. also i turned up the turbo :D
much great improvement
mikey
