tand77 Posted October 11, 2009 Posted October 11, 2009 hi my disco 200dti fitted to a defender 90 is smoking black smoke only when you floor throttle and the engine is trying to catch up if you easy off smoke clears the is a bit of oil in the turbo pipes but i have clean out intercooler any idears thanks andy Quote
Guest otchie1 Posted October 14, 2009 Posted October 14, 2009 hi my disco 200dti fitted to a defender 90 is smoking black smoke only when you floor throttle and the engine is trying to catch up if you easy off smoke clears the is a bit of oil in the turbo pipes but i have clean out intercooler any idears thanks andy Too much fuel/not enough air. Blocked air filter? Blank off the EGR? Quote
fender1234 Posted October 14, 2009 Posted October 14, 2009 Has the fuel pump been tweaked before? Quote
chappers Posted October 17, 2009 Posted October 17, 2009 that's definstly a blocked filter or a fuel pump set up wrong maybe wind the turbo up a bit to compensate and you get an increase in power if not then on here some where there is a posting about tweaking the fuel pump read that and put it to how it was in that post then it will be standard and shouldn't smoke =] hope that makes sense cheers Sam Quote
