jacks906 Posted October 11, 2009 Posted October 11, 2009 looking at up grading or change an lt77 maybe with another if we can find one or fit an r380 (if that is possible) but we have a long shaft disco box which not sure if can just change the shafts. if this makes sence to anyone which do you think is the best option dave Quote
jimmy_neutron Posted October 12, 2009 Posted October 12, 2009 My opinion is to use a defender r380 suffix L as a base and convert it to a short r380. This is what i did. Its quite expensive to do though and needs more parts than you would probably think. Throw the disco box away though as the shifter is different. If your looking for cheap fix then get another lt77 or better still send yours to ashcrofts. Quote
JonR Posted October 13, 2009 Posted October 13, 2009 My opinion is to use a defender r380 suffix L as a base and convert it to a short r380. This is what i did. Its quite expensive to do though and needs more parts than you would probably think. Throw the disco box away though as the shifter is different. If your looking for cheap fix then get another lt77 or better still send yours to ashcrofts. What bellhousing did you use? Jon. Quote
Ex Member Posted October 13, 2009 Posted October 13, 2009 Just an FYI that Ashcroft should be very close to selling short shaft R380s. Quote
JonR Posted October 13, 2009 Posted October 13, 2009 Just an FYI that Ashcroft should be very close to selling short shaft R380s. Yes, when I spoke to them at Billing in july, they said september... Apparently the bellhousing manufacture was causing the delay. Jon. Quote
