ollie nz Posted October 12, 2009 Posted October 12, 2009 Hi all,this morning I noticed a slight slipping when clutch let out,thought may need new one,but have used all day and no more slipping,have tried a few times on some very steep hills,but all is perfect,done 120,000 ks 03 90, any ideas ? Quote
headhunter Posted October 12, 2009 Posted October 12, 2009 You can do some adjustment at the master cylinder piston rod end, try a search in our technical archive. John Quote
nicks90 Posted October 12, 2009 Posted October 12, 2009 have a nosey about under the bellhousing and check for oil leaks dripping out of the drain plug. ciould be a bit of oil contamination on the friction plate. Quote
ollie nz Posted October 12, 2009 Author Posted October 12, 2009 [quote name='nicks90' THANKS NICK,WILL GIVE THAT A TRY ,CHEERS Quote
ollie nz Posted October 12, 2009 Author Posted October 12, 2009 THANKYOU JOHN,WILL GIVE THAT IDEA A GO,REGARDS STEVE Quote
