john bowling Posted October 13, 2009 Posted October 13, 2009 Previous owner has pulled the tamper proof plug and adjusted the idle air bleed, i corrected the inlet manifold air leak but now need the correct procedure for setting the base idle, i can reset the adaptive idle after thanks john Quote
vougese39 Posted October 14, 2009 Posted October 14, 2009 Previous owner has pulled the tamper proof plug and adjusted the idle air bleed, i corrected the inlet manifold air leak but now need the correct procedure for setting the base idle, i can reset the adaptive idle after thanks john needs to be done by testbook if it is a classic simple on the gems system it is done electronicaly Quote
