Posted
When I bought my disco it didnt come with a remote locking fob, and as such, i have been locking and unlocking it on the key.
I have just discovered the spaare keys for my old disco, including the fob.
What i'm asking is can a second hand fob be programmed to any vehicle? Both trucks were the same age. (early 300 series with single button)
Any help would be appreciated
Cheers Roland
Posted
Cheers Roland
A single button fob is user programable. How to do it has been posted before in the forum, open the bonnet, hold down the switch etc etc.
Posted
NOTE: New handsets are supplied in pairs.
If a new handset is required, it will require
initialisation to the ECU using the
following procedure:
1. Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2. Carry out instructions 3. to 9. within 8 seconds.
3. Switch ignition ON.
4. Switch ignition OFF.
5. Lock doors.
6. Unlock doors.
7. Release bonnet switch.
8. Switch ignition ON.
9. Switch ignition OFF.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10. Press and hold down button on first handset until
dash LED flashes.
11. Repeat instruction 10. for second handset.
12. The LED will extinguish if both handsets have
been initialised correctly.
  • 3 months later...
Posted
Just tried the above drills but I've got a 2 button fob. One with a padlock sign and the other with the land rover logo. Any clues on how to reset this type of keyfob?
