jmattley Posted October 14, 2009 Posted October 14, 2009 As the name implies, my 200 disco has a leeky coolant system, but I'm not sure where exactly, it's alarmingly quick in that most of the coolant will disapear within a week! Even if left standing! Are there any places I should look that are common to 200s at all? Cheers! Quote
Les Henson Posted October 14, 2009 Posted October 14, 2009 If you have antifreeze in it, then the leak will leave a coloured mark from it (blue, green, pink - whichever you use) Water pump is a favourite (look under the nose of it - there's a hole there). Heater matrix is another, but if you had antifreeze in it - you would smell it (sickly sweet smell). If there are no evident marks on the ground from the leak, then start the engine - as it warms up, coolant pressure will increase and push it out faster. Les. Quote
