wayne1978trucks Posted October 14, 2009 Share Posted October 14, 2009 As title sugests my rear floor in my 110 csw was removed from the kick plate for the 2nd row seats to the back door ive now completed the full strip and respray of the chassis and have all new underfloor crossmembers but need to get the floor and kick plate section made. Could i (as my mate makes heavy duty plastic presses) get this section made from 6mm plastic sheet that will be plastic welded to form a bolt in floor section with the cross members plastic welded to the under side of the floor, he says it will never rot and is stronger than the origional alloy. As the section is not structural and the seatbelts/seats will still be bolted to the cross members would you see any probs with mr mot or vosa ? Quote Link to comment Share on other sites More sharing options...
tacr2man Posted October 14, 2009 Share Posted October 14, 2009 If its as you say then I cant see it being a problem , as mot only takes into account corrosion , and as you say its not structural , its not something that you are going to get a definite answer to tho, I doubt even if you took it to vosa they would be very wary about giving a straight answer . Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted October 14, 2009 Share Posted October 14, 2009 i highly doubt you will get pulled up on it! I certainly think its a very good idea!! Quote Link to comment Share on other sites More sharing options...
