JCB Posted April 6, 2006 Share Posted April 6, 2006 I remeber a thread somewhere about an adative you could put in the that helped cure slight leaks. What is it? Quote Link to comment Share on other sites More sharing options...
white90 Posted April 6, 2006 Share Posted April 6, 2006 brake fluid, a capfull will assist in putting off the ineviatable box replacment/rebuild, it swells the seals. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 7, 2006 Share Posted April 7, 2006 Slick50 sell a transmission fluid that has something in it that does the same thing. I've seen it used on a small leak and work, but gushers will still gush. Les. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 9, 2006 Share Posted April 9, 2006 yep, brake fluid works, stopped mine leaking completely... Quote Link to comment Share on other sites More sharing options...
VERY OLD DISCO Posted April 11, 2006 Share Posted April 11, 2006 Oh goody, I will try that, nothing to lose, mine leaks even after changing the seal, I was going to buy some "seal swell" but since brake fluid is cheaper I will give it a go. Geoff Quote Link to comment Share on other sites More sharing options...
