Posted
OK so the title rules out half the members here :unsure:
I tried to ask one of the exulted ones but it seems that he has an issue with a gearbox. :(
Will a P38 4.0 EFI manifold and Plenum work on a 3.5 with Megasquirt?
I have looked at the MS topic and it looks like all the later injectors are the same so it comes down to the air flow rate. Will it flow too much air to be set up correctly?
Can the panel please advise :)
Cheers,
Marc.
Posted
I suspect it will be fine.
If the manifold runners are larger than the 3.5 equivalent you'll probably shift the power up the rev range a bit, but i cant see it being a problem and i doubt theres much difference in the runners anyway.
Posted
See no reason why not.
It will only breath as much as it needs which begs the next question
Why not fit a whole 4.0 and not just the top bits? You know you want to.
Steve
Posted
Steve
Top bit £25.
Whole bit £xxxxx
Posted
The only problem I can think of would be the clearance (or lack of) for the distributor. Obviously you don't need the distributor as such for the ignition if you go MS but you do need something to drive the oil pump.
You'll need to supply a fuel pressure regulator (an adjustable after market one like the Mallory one) as the Thor doesn't have a regulator on the manifold (or a return) but uses a regulator at the pump instead. This isn't a bad thing though as it will allow you to adjust the pressure to suit your engine/fuel requirements/injectors.
Posted
Thanks,
You have matched one of my thoughts.
The other is a bit of a concern but hopefully MS and a lower Dizzy for the oil pump drive. :unsure:
Marc.
Posted
I am looking at an early P38 manifold GEMS not Thor.
I would love a Thor but I have never seen one yet.
Cheers,
Marc.
Posted
Early P38 manifold gains you nothing whatsoever over the earlier stuff - it's basically the same. Throttle mouth is the same diameter etc. etc. it's just a few drillings and ancillaries that are different. Only worthwhile thing is going from flapper to hotwire which gets you clamp-down type injectors and loses the injector resistor pack (high impedance injectors).
Posted
Cheers,
Marc.
You fooled us with the 4.0, as above, no benefit really in changing to a GEMS manifold. Thor manifolds are available, I've seen a few come up - I have one in the garage somewhere.
Posted
Sorry about the confusion.
I wanted an EFI for Megasquirt and this came up cheep so I wanted to get it but needed help.
This information is even better as I could not side to side it with an old one.
It is interesting that the throttle mouth looks bigger until you compare it.
Main reason for going with this one was cost and the fact that it was newer than the other ones for sale so I expect less wear on the throttle spindle?
Actually it looks more compact (a bit).
Fridge,
I didn't know that you had lots of manifolds! If this has high impedance injectors then this could potentially work with Microsquirt? I know you are not keen on it but it is waterproof and small so it seems a good idea if it can handle the power.
Do you have any EDIS-8s for sale as I am after one :P
Thanks for the great information so far.
Marc.
Posted
As long as you can sort the plumbing, yes no reason it won't work. Didn't they have a returnless fuel line or something?
GEMS doesn't, well at least the one in my garage has a regular return just like the hotwire setup.
Am i right in thinking the Thor-type manifold doesnt have a thermostat housing?
Neither does RR GEMS system, the thermostat is a plastic housing that sits in the bottom hose -think it is the same/similar in a 300TDI.
I'm putting together a GEMS 4.0 setup to go in my RR, converting from the hotwire setup on my dead 3.9, so when I'm done I'll let you know of any wiring differences.
Posted
The flapper 3.5 Plenum/manifold is easier to MegaSquirt than the hotwire because the idle control is built in and you don't need to worry about it. You could use the injectors from the GEMS manifold if the flapper injectors are low impedance but MS will work happily with both anyway.
Posted
Fridge,
My doubts about MicroSquirt are based on using high impedance injectors - it definitely can't handle 8 low impedance ones, and even high impedance is borderline.
Why do you need your ECU to work underwater unless you're bolting it under the car? Wires can be moved, my ECU is above my head so if it gets wet I've got bigger problems. TBH once the PCB is conformally coated they'll handle the odd dunk anyway - ask Rog! The microsquirt also needs the MAP sensor mounted externally.
My setup is 3.5 top end with 3.9 injectors & fuel rail, and will be getting a PWM idle valve. The flapper one is fit-and-forget but you then have none of the idle stabilisation / stall prevention that you get from the ECU controlled one.
No I don't have any EDIS-8's for sale at the moment, check my sig :P
