Posted
Hi,
I am after some second hand kit for a 1990 Disco 1. I am in NI so it will need to be parcel force or courier sent they most likely charge by weight. I may be able to organise it from my end? I do not mind if someone can make the parts up providing they look the business and made from 6mm or more plate. Parts required are.
1/ steering guard (recovery and hi lift points if possible)
2/ front axle guard
3/ rear diff guard (sliding type if possible)
4/ fuel tank guard
:rolleyes:
Posted
O dear no fabricators :(
Well can anyone point me in the direction of who can supply my under bits at a fair price.
The Disco will not be used that often, as I have a 110 with Southdown kit.
I just want the Disco for emergencies.
  • 2 weeks later...
Posted
Thanks for the pointer I,ve had a look at Rebels stuff and it will do ok if nothing else appears.
Have you put any protection on for the steering arm and damper at the rear of the front axle.
My Southdown kit on the 110 is good. I have had it on for 6 years now and no poblems bought when times were better.
