cw01 Posted October 16, 2009 Share Posted October 16, 2009 Hello all, I know its not a Defender, but I need to change the complete exhaust on my '86 110. I have all the pipes, and the fitting kit, but unfortuneatly I am a complete biff. I have no fitting instructions, nor can I find any. Would any one be able to assisit me with how to do this?, or point me in the direction of fitting instructions. Cheers, Chris. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted October 16, 2009 Share Posted October 16, 2009 nothing complex to it, just a few nuts n bolts really. from memory though, you may need to remove the front crossmember (there are four bolts on each side) in order to get the front downpipe off. If you are replacing an existing system, just take note of the route the pipe takes over the axle/chassis at the rear. having some bits of string handy can be useful to tie up the pipe sections while you get the joints assembled, saves your arms a bit.. If you can get new hangers and rubbers etc it means you can just cut off the old ones as they are probably seized up to buggery and can be a pig to get off. Quote Link to comment Share on other sites More sharing options...
