SteveG Posted April 7, 2006 Share Posted April 7, 2006 I've downloaded the Midalnd 48 Excel user manual and the Midland 48 Multi manual as there isn't one for the Midland 48 Excel Multi and I still can't work out how to change the country frequency on mine. It stuck on 'i' Italy so useless in UK tried holding down am/fm and scan while turning on as on 48 Multi but no good. Also tried every other two button combination while I was there Help! Cheers Steve Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted April 7, 2006 Share Posted April 7, 2006 Procedure: 1. Switch off the unit. 2. Turn it on while pushing the “AM/FM” e “SCAN” buttons at the same time. 3. Rotate the “CHANNEL” knob and select the desired frequency band (see the chart here below). 4. To stop your selection, press the “AM/FM” button. NOTE1: In the UK frequency band, you can select directly the EC band by pushing the “AM/FM” button for 2 seconds. NOTE2: If you select a frequency band which operates in FM mode only, the “AM/FM” control enables the LCR function (Last Channel Recall). info from http://www.cte.it/home_eng.asp it worked for my rig, but ? is the Excel multi different then???? This is the 'Plus' Multi from their web site: The info/downloads are on the above link, hope it helps. Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 7, 2006 Author Share Posted April 7, 2006 Yep tried that and no joy. Must be different or very bad user error Steve Quote Link to comment Share on other sites More sharing options...
cols110 Posted April 9, 2006 Share Posted April 9, 2006 OK here`s your answer out of the book, your book infact, check your PMs. Turn the radio on whilst holding the NK button Rotate the channel selector until you get to the UK freq Push the LOCK button to lock in the selection Then PM me your address so I can get the instruction manual to you in the mail. Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 9, 2006 Author Share Posted April 9, 2006 OK here`s your answer out of the book, your book infact, check your PMs.Turn the radio on whilst holding the NK button Rotate the channel selector until you get to the UK freq Push the LOCK button to lock in the selection Then PM me your address so I can get the instruction manual to you in the mail. Cheers Col, thanks for this I'll drop you a PM back Thanks Steve Quote Link to comment Share on other sites More sharing options...
