mobyone Posted October 25, 2009 Share Posted October 25, 2009 i bought a quite good condition 300tdi 5 door yesterday with a siezed engine. i have a spare anyway, but was considering overhauling the engine. when i got it home i looked further into it, the guy thought the oil pump had failed, though i have not heard of this often on these engines, and found next to no coolant- which is almost certainly the cause of the sieze. anyway, the point of this topic is, other than the obvious 1. head 2.cylinders 3.check all water hoses 4.rings/pistons. 5.water pump 6. block cracked!! what else should i look for. i haven't really got into the nitty gritty on these engies yet so i figured it was about time. have done lots of in-situ type stuff apart from a head swap, but never ripped these engines apart to re build again. so what in my list did i miss? thanks guys/girls in advance richard Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 25, 2009 Share Posted October 25, 2009 I bought my 300TDi engine dirt cheap (£50) because it had been boiled and fried. The pistons had picked-up in the bores, so a rebore and new pistons. The head was warped beyond saving, so a new head from Turner Engineering. Cam and crankshaft bearings were shot, but the cam and crank were still ok. The engine had been sat outside with some old carpet on it, so was in a pretty bad state. Les. Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted October 25, 2009 Share Posted October 25, 2009 Neat job. I was thinking of rebuilding a 300tdi as a spare for my own Disco. Is there anywhere on here that takes me through the sequence or is it a case of take it apart and rubuild all and sundry Hugh Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 25, 2009 Share Posted October 25, 2009 I did bits and pieces of the rebuild and took pictures of the whole job as I went, but not a single thread on it. It's not the sort of thing that someoe is likely to do, so I didn't think it was worth it. Les. Quote Link to comment Share on other sites More sharing options...
martinhollings Posted October 25, 2009 Share Posted October 25, 2009 try this http://www.turner-engineering.co.uk/html/articles.html Quote Link to comment Share on other sites More sharing options...
elbekko Posted October 25, 2009 Share Posted October 25, 2009 I did bits and pieces of the rebuild and took pictures of the whole job as I went, but not a single thread on it. It's not the sort of thing that someoe is likely to do, so I didn't think it was worth it. Les. I wouldn't mind a write-up on a 300tdi rebuild, especially what parts and tools to get etc. I have the rebuild manual, but it looks like you need a different tool to get each pulley out Quote Link to comment Share on other sites More sharing options...
mobyone Posted October 25, 2009 Author Share Posted October 25, 2009 well, forget the rebuild... i cant even split it from the g/box. got all but one nut from the bellhousing and the one left is well chewed up. it is as if someone has tried a nut splitter on it but could not get it split properly. i have never removed an engine let alone one with the box still on it. anyone got any tips on either way. oh and it is the one about the 3 o'clock position looking at the engine from the front. i have an engine crane too. richard Quote Link to comment Share on other sites More sharing options...
thebiglad Posted October 25, 2009 Share Posted October 25, 2009 I bought my 300TDi engine dirt cheap (£50) because it had been boiled and fried. The pistons had picked-up in the bores, so a rebore and new pistons. The head was warped beyond saving, so a new head from Turner Engineering. Cam and crankshaft bearings were shot, but the cam and crank were still ok. The engine had been sat outside with some old carpet on it, so was in a pretty bad state. Les. Hi Les, that looks like a beautiful result you achieved there, I'd be as proud as Punch if my TDi engines looked like that. Very well done. So, now that you've got the hang of it.................................................................... Quote Link to comment Share on other sites More sharing options...
