muddy Posted October 25, 2009 Share Posted October 25, 2009 Mornin all, i have a bulkhead swap to do on a turbo diesel 90 and would like to amass atleast some new parts to help with this. So far i have the following: Wing to heater duct seal MRC9998 Heater to bulkhead seal MTC6871 OR STC952 (any idea wich one i need?) Windcsreen to roof seal MTC6568 Windscreen to bulkhead FAJ100020 Outrigger bolts M12x180mm MRC9420 Those little plastic inserts self tappers screw into (where can i buy these in bulk?) RTC3744 Wheelarch spat rivits AFU1075 (again can these be bought in bulk?) I will also be buying a MUD bolt kit so all the hinges should be taken care of. Cheers, Will. Quote Link to comment Share on other sites More sharing options...
western Posted October 25, 2009 Share Posted October 25, 2009 RTC3744 AFU1075 usually in packets of 10 IIRC MTC6871 see diagram 2 item 23 & STC952 see diagram 1 item 2 looking at the parts book/Micrcat the MTC6871 looks to fit on the cab side of bulkhead between dash & bulkhead & the STC952 looks to fit between the heater box & bulkhead, so I believe you'll need both seals. all from LRSeries website Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted October 25, 2009 Share Posted October 25, 2009 Assuming the replacement bulkhead has been stripped etc you will need the little clip things that hold the brake pipes to the bulkhead. Other than that i think you have covered it! Quote Link to comment Share on other sites More sharing options...
Phillis Posted October 25, 2009 Share Posted October 25, 2009 how many.. Outrigger bolts M12x180mm MRC9420 ? do you need for a bulkhead replacement? Quote Link to comment Share on other sites More sharing options...
western Posted October 25, 2009 Share Posted October 25, 2009 only 2 required, one each side. Quote Link to comment Share on other sites More sharing options...
Marco Posted October 25, 2009 Share Posted October 25, 2009 I do advice not to fit a stainless steel hinge bolt kit.... The steel hinge + stainless steel bolts will make the hinge rust 10+ times faster due to tension corrosion between the two types of metal. Better upgrade to the newer type (zinc?) plated hinge + new torx bolts, that's what I did after first spending the cash on the stainless steel bolts (now free to collect in Holland ) Cheers Marco Quote Link to comment Share on other sites More sharing options...
