Transfer box oil
Does anyone know if this offering would be OK for axles and transfer box on my 90. The price seems very attractive!
[LINK]http://www.screwfix.com/prods/66754/Van-Car-Accessories/Car-Lubricants/Carlube-Hypoid-Gear-Oil-EP80w90-4-55Ltr[/LINK]
If it is then I will get some since needing to top up soon.
Thanks
Malcy
Yes it will be fine, though it is a GL4 spec oil. Latest (higher spec) is GL5.
Regards,
Diff
Thanks Diff
Mine is a 1991 Defender so I guess the older spec will be OK.
As far as I know gl4 is the correct spec oil for your transfer box. The older boxes had brass or bronze (not sure which) parts in them which gl5 oil reacts with and causes them to fail. Its fine in the diffs though.
