ajh Posted October 30, 2009 Share Posted October 30, 2009 So I got an R380 for my 200TDI, the only thing is there is no clutch slave cylinder in place. Even if the one from the LT77 fits I think I would feel better fitting a new one (got the TD5 pedal/master coming) while things are all split apart and easy to access. My only question is what parts do I need to order to do this? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted October 30, 2009 Share Posted October 30, 2009 I would suggest that it is best to talk with Dave Ashcroft. The short shaft R380 is very special and he will know which slave cylinder is correct. A list of other slave parts is shown at: http://www.ashcroft-transmissions.co.uk/part_119.html Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted October 31, 2009 Share Posted October 31, 2009 Just use the standard slave cylinder http://www.paddockspares.com/sp/cat/DEFENDER/sub/Clutch/sid/12/sb2/6++Miscellaneous+Clutch+Parts.html but you will need .. FTC4229 : Slave cylinder pin as the distance from the front of the cylinder to the clutch fork is different than standard. Make sure that you don't fit the standard tdi clutch release bearing. There's a parts list on the bottom of page 2 on my linky thingy below if you need it. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted October 31, 2009 Share Posted October 31, 2009 looked everywhere for that info when I did mine! I ended up putting the old pin back in even though it was rough as a badger's arse FTC4229 - duly noted (for next time...) Quote Link to comment Share on other sites More sharing options...
ajh Posted October 31, 2009 Author Share Posted October 31, 2009 So in confusion do I require 591231G (clutch slave all model except 300TDI) or do I need one of the 300TDI ones? The listings make it as clear as mud... I need to place an order today as I am departing for a month in Peru on Monday and hope that all my parts including my new front and rear doors (yay, late model doors!) and OE roof rack will be here when I get home. No doubt I'll need more things before I can finish re-assembly, but then is that not always the way. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 1, 2009 Share Posted November 1, 2009 Just guessing, put I suspect the slave should match the master. If you have a 300TDI master, then you should have a 300TDI slave.... Like I say, ask Dave Ashcroft.... Friendly, helpful and does not guess... Quote Link to comment Share on other sites More sharing options...
ajh Posted November 1, 2009 Author Share Posted November 1, 2009 I would but I leave for Peru on Monday, I did send an email so perhaps he'll respond before I have to head to the airport and I can forward the details on. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted November 1, 2009 Share Posted November 1, 2009 Sorry I didn't make it clear did i I've got a 591231G on my short r380. I also got the 300tdi onwards clutch pedal assembly to give me the softer clutch pedal. Clutch master is the standard 200tdi. I've not looked at the later slave cylinder so don't know what the differences are and if the mountings etc are the same. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted November 2, 2009 Share Posted November 2, 2009 I've not looked at the later slave cylinder so don't know what the differences are and if the mountings etc are the same. I *think* the - or at least *a* - difference is the thread of the pipe fittings (metric versus UNF) I got a FTC5072 to go in my ex-MOD 2.5NA / R380 and it bolted up to the bellhousing fine, and accepted the old rod - but I had all sorts of issues with the hydraulics - see here: http://forums.lr4x4....=1entry194977 Hopefully the 591231 will connect right up with your existing piping OTOH if you are fitting the TD5 pipes as well as master / pedal then you may want the metric slave - I'd second the motion of checking with Ashcrofts - I know how frustrating it is when you are trying to do this all so far away from Solihull Quote Link to comment Share on other sites More sharing options...
western Posted November 2, 2009 Share Posted November 2, 2009 Sorry I didn't make it clear did i I've got a 591231G on my short r380. I also got the 300tdi onwards clutch pedal assembly to give me the softer clutch pedal. Clutch master is the standard 200tdi. I've not looked at the later slave cylinder so don't know what the differences are and if the mountings etc are the same. my short shaft R380 has the 591231 slave cylinder on it. works fine with the standard clutch master 550732 & later 300tdi pedal assembly. Quote Link to comment Share on other sites More sharing options...
