diff lock light problem
hi i have just got a defender 90 200tdi im having problems with the diff lock light its not coming on it seams like the diff lock is working but no light (checked and changed bulb) is there a switch in the box that might be faulty or needs adjusting ? what should i check for many thanks graham
  • Like 1
http://picasaweb.google.co.uk/lh/photo/kWZOWop3pLyJsWpeY9-0_g?feat=directlink
Linkage slide like the above, the spring-loaded collar slides the cogs together. The light is engaged with a pin that rides up over that linkage. Maybe it's screwed out too far. Check it's actually engaging at all first before worrying about the light.
I have this exact problem as well , havent looked at it yet but was expecting just the bulb to be gone as my difflock still works just no warning light
Another possibility is that the wiring (it goes from top front of bulkhead to transfer box switch along the chassis rail, and has a least one joint in it) has gone brittle, corroded and otherwise ceased to conduct. You can get to most of fairly easily (assuming the floorscrews will come out :ph34r: ) by taking the right hand floor panel out.
spot on the wire for the light was not even pluged in it was tucked up by the bulkhead thanks for all your time and help people :D
I`ve already got my floor panels off and your right i just traced wires ,, they were high resistance at gearbox end
HTH and glad you're both sorted. Mine had turned into copper rust for about the last two feet, it just fell apart when I pulled. The reverse light wiring goes this way too eventually, but takes longer.
