cbmark Posted November 9, 2009 Share Posted November 9, 2009 im slowly building up a disco one and want to build it once if that makes sence im looking at shocks now my question is will say procomp +4 or terrafirma +5 shocks fit straight on or will they just be perm bottomed out? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted November 10, 2009 Share Posted November 10, 2009 You mean you want to fit +4/+5 dampers with the standard/factory springs? If yes, then the dampers will get bottomed and they will get damaged in no time so don't do it. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted November 11, 2009 Share Posted November 11, 2009 Nothing wrong with using +5s with standard springs. You must use the correct mounts though. Quote Link to comment Share on other sites More sharing options...
cbmark Posted November 11, 2009 Author Share Posted November 11, 2009 sorry forgot to say its with +2" springs what is the score then what mounts do i need to buy or is it a waste of time reason for doing this is i want real good articulation and any pointers would be a great help Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted November 11, 2009 Share Posted November 11, 2009 If you want really good articulation then if you already havent, having the correct poundage springs and cranked trailing arms will help alot. If you have got both of them sorted then get the shocks but you will need mounts really otherwise even with +2" springs they will bottom out and get damaged quickly, the mounts are not expensive either gwyn lewis even does weld together mounts which are even cheaper. Dave. Quote Link to comment Share on other sites More sharing options...
