series3_mad Posted April 14, 2006 Share Posted April 14, 2006 Im picking up 2 salisbury rear from a LWB series 3 on monday and i m thinking about putting one on my landy and im just wondering if it would be a straight foreward swap or do i have to modify it in any way? cheers Matt Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted April 15, 2006 Share Posted April 15, 2006 Im picking up 2 salisbury rear from a LWB series 3 on monday and i m thinking about putting one on my landy and im just wondering if it would be a straight foreward swap or do i have to modify it in any way?cheers Matt You'll have to move the spring seats, as the spring sit outside the chassis on a 109. The brakes might be a different size (yours will just bolt on). And your prop will need shortening by around an inch. It'll ruin your ground clearance though. Quote Link to comment Share on other sites More sharing options...
selectcase Posted April 15, 2006 Share Posted April 15, 2006 If you want a ready made prop for the conversion I have one Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted April 27, 2006 Share Posted April 27, 2006 If you want a ready converted axle, with the spring seats moved across already, I've got one... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 30, 2006 Share Posted April 30, 2006 If you want the ground clearance back, have a look here. A worthwhile mod sticking a salisbury on IMHO, much stronger than Rover axles. Quote Link to comment Share on other sites More sharing options...
series3_mad Posted May 3, 2006 Author Share Posted May 3, 2006 just wondering why does the prop need shortening Quote Link to comment Share on other sites More sharing options...
Tonk Posted May 3, 2006 Share Posted May 3, 2006 salisbury axles have a longer diff nose Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 5, 2006 Share Posted May 5, 2006 When i fitted a salisbury to my 90, the prop needed shortening by 1 3/4" IIRC. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 6, 2006 Share Posted May 6, 2006 Why not go the whole hog and chop the other one up to make a Salisbury front? Quote Link to comment Share on other sites More sharing options...
