trickydicky Posted December 1, 2009 Share Posted December 1, 2009 hi i brought some springs off ebay from a 06 td5 defender but now i dont know witch one goes were i have cheked the colour codes but carnt figgure it out. i have 2x yellow and white (rear) 1x blue and red (?) and 1x blue and green (?). also is there a right way up? Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2009 Share Posted December 1, 2009 IIRC the coils closet together go at the bottom. colour codes are Here Quote Link to comment Share on other sites More sharing options...
trickydicky Posted December 1, 2009 Author Share Posted December 1, 2009 IIRC the colis closet together go at the bottom. colour codes are Here thats the colour codes iv bean looking at but if thats true then i have 1 spring from a 110/130 and the other from a disco but that carnt be so. thay are both the same hight and thickness. the back ones are ok its just the front i carnt find i thought perhaps the td5 wasnt on that list or something Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted December 1, 2009 Share Posted December 1, 2009 From memory:- Blue/red is drivers side rear. Yellow/White is passenger side rear. Blue/green is drivers side front. Blue/yellow is passenger side front. Just checked the link which confirms the above. Pete. Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2009 Share Posted December 1, 2009 brown/purple is Td5 defender rear springs, bit more info http://members.shaw.ca/jbarge/RKB101111.html & I was wrong going by the photo in the link the closest coils sit at the top. NRC9449 90 Rear passenger side yellow/white NRC9448 90 Rear drivers side blue/red NRC9446 D90, Disco HD Front drivers side blue/green Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 1, 2009 Share Posted December 1, 2009 Someone please explain to me how a variable rate spring knows which way up it is??????? Tighter coils at the bottom = harder to do up retaining bolts and more of a mud trap. Tighter coils at the top = the end of the world maybe? Until a grown up proves me wrong, I don't believe the orientation makes a blind bit of difference. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 1, 2009 Share Posted December 1, 2009 'Twas what I had always believed, not a jot of difference. But now, thinking about it Closer coils at the bottom would lead to marginally increased unsprung weight, whereas at the top would be slightly lower unsprung weight, but then this is a Land Rover, not a sports car where every gram matters Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 1, 2009 Share Posted December 1, 2009 Whilst this subject is open, perhaps someone can answer a question for me. Are 90 TD5 springs handed ? I'd have thought not as the fuel tank is now at the back and central but I'm curious to see if anyone knows. Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2009 Share Posted December 1, 2009 IIRC LR stopped handing springs from Td5 vehicles onwards. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 1, 2009 Share Posted December 1, 2009 I wonder if anyone has the part numbers for TD5 90 standard springs ... Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2009 Share Posted December 1, 2009 I wonder if anyone has the part numbers for TD5 90 standard springs ... Mo might have Td5 rear springs RKB101230 Yellow/red RKB101240 Yellow/white Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 1, 2009 Share Posted December 1, 2009 Thanks Ralph, that's useful Does that mean that the springs are actually handed then, since there is a different part number for each of the rear springs ? Do you know the front spring numbers ? Quote Link to comment Share on other sites More sharing options...
trickydicky Posted December 2, 2009 Author Share Posted December 2, 2009 hi is there anybody out there who can tell me witch springs i have and were they go? reading this thread from the top its very confusing the first link tells me that the yellow and white springs are for the rear then somebody said the drivers side is blue and red but if thats so then were douse the other yellow and white go? has anybody got an 06 td5 90 with standerd spring? ps the coils are the same all the way up there arnt any tighter ones and the yellow and white are 15mm shorter than the blue and red and the blue and green Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted December 2, 2009 Share Posted December 2, 2009 (edited) For a Pre TD5 90 the springs are as follows:- Part No Duty Axle Length Rate Number of coils Code NRC9448 D90 Rear drivers side 15.31 225 8 blue/red NRC9449 D90 Rear drivers side 14.80 225 8 yellow/white NRC9446 D90 Front drivers side 15.19 175 7.75 blue/green NRC9447 D90 Front Passenger Side 14.80 175 7.75 Blue/Yellow This information is cut and pasted from the table in the link above. Some of the springs have multiple use as front springs on other vehicles (ie RC9448 and NRC9449 are used as HD fronts on 110 and 130.) As Western has posted the TD5 rears should be (P/n RKB101230) Yellow/red and (P/n RKB101240) Yellow/white Pete. Edited December 2, 2009 by Pete Attryde Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 2, 2009 Share Posted December 2, 2009 Sounds like you have three rears and a front.... Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2009 Share Posted December 2, 2009 Thanks Ralph, that's useful Does that mean that the springs are actually handed then, since there is a different part number for each of the rear springs ? Do you know the front spring numbers ? 90 front Drivers side NRC9446 Passenger side NRC9447 Quote Link to comment Share on other sites More sharing options...
trickydicky Posted December 2, 2009 Author Share Posted December 2, 2009 Sounds like you have three rears and a front.... so what happens if i put 2 yellow and white on the back? i only need to change the back i am suffering from saggy bottom. well not me its the landy Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2009 Share Posted December 2, 2009 nothing will happen, 2 springs of same length & rate will work. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted December 2, 2009 Author Share Posted December 2, 2009 nothing will happen, 2 springs of same length & rate will work. whith the springs i have what would be the best combination for the back of an early defender (1990) Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 2, 2009 Share Posted December 2, 2009 Stock is blue/red on driver's side and yellow/white on passenger's side. Blue/green is a normal front spring. Why are you changing the springs? Why did you pay money for used stock springs? You could get a dozen for free any day of the week. 70% of the people on here have aftermarket springs with stock ones lying around getting old. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted December 2, 2009 Author Share Posted December 2, 2009 Stock is blue/red on driver's side and yellow/white on passenger's side. Blue/green is a normal front spring. Why are you changing the springs? Why did you pay money for used stock springs? You could get a dozen for free any day of the week. 70% of the people on here have aftermarket springs with stock ones lying around getting old. i just wont to keep it all standard ish and i dont know anybody who is giving away deacent spring for free Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted December 3, 2009 Share Posted December 3, 2009 As you state you only need to change the rears, and as you have a red/blue and a yellow/white (which are the factory fitted standard rear springs), I would do as Red90 suggests and fit them to the rear. This should if the springs are in better condition than your existing rear springs solve your problem. However as the seller has provided you (if the colour codes you list are correct) with three rears and one front I would be a little worried about the condition of said springs . Pete. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 3, 2009 Share Posted December 3, 2009 90 front Drivers side NRC9446 Passenger side NRC9447 Splendid, thanks Ralph Quote Link to comment Share on other sites More sharing options...
trickydicky Posted December 3, 2009 Author Share Posted December 3, 2009 the springs on the little girl at the moment are almost 20 years old and very rusty these look brand new so im thinking for £20 i dont have much to lose thanks for the replies everybody ill let you know what they are like after the weekend (weather permitting) Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 3, 2009 Share Posted December 3, 2009 Let us know how you get on dicky, I'm curious to see if they do improve things. Got to be better than the old ones, surely. Mo Quote Link to comment Share on other sites More sharing options...
