Jon White Posted April 20, 2006 Share Posted April 20, 2006 But even if it's a 0.5mm offset between bearings, that doesn't cater for the disc being around 2.5mm offset from the middle of the calliper body, I've never had a bearing that badly out of tolerance I have - mine was about 3mm out. Not saying it is the problem, just saying check it! Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted April 20, 2006 Share Posted April 20, 2006 Stub axle tolerances? If you were feeling investigative, could you swap the stubs from side to side and see if there was a difference? Of course, you probably don't want to see the thing in daylight again... Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 20, 2006 Share Posted April 20, 2006 worth checkin the machinin on the TI hubs aswell, could always shim the inner race cup so it offsets the whole hub if needs be Quote Link to comment Share on other sites More sharing options...
isuzurover Posted April 20, 2006 Share Posted April 20, 2006 They made the hub it's part of the kit as they manufacturer it to fit the disc And you have seen what the rest of the tolerances are like so why are you surprised??? Quote Link to comment Share on other sites More sharing options...
minivin Posted April 20, 2006 Author Share Posted April 20, 2006 well, went out side, hunched under the wheel arch and the tyre on the side that's complete <harrumph> "can't see any easy datum points". Started to drizzle at that point so thought I had better get the drive flange on the other side and the stub cap and bits fitted before it fills with water. Get the bits on so that it leaves just the caliper and wheel to do and it heeves it down, indoors and good night for tonight Gonna skim the calliper bracket tomorrow as the hassle of stripping bits off to measure up again don't seem that intising at this time give it a few weeks and I'll pull the wheel's off and do some basic measurements then, and when something goes "pop" I'll strip the assembly and do complete measurements then. Two days work so far so can't be farce-ed to rest much more time, as I got a motorbike to prep for a hillclimb next month Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted April 21, 2006 Share Posted April 21, 2006 you also have a landrover that needs to be fit for a 3,000 mile trip Quote Link to comment Share on other sites More sharing options...
minivin Posted April 21, 2006 Author Share Posted April 21, 2006 tell me about it, a week wasted, if lucky some of the other conversion plans bits will be ready by next week Quote Link to comment Share on other sites More sharing options...
