The Homba Posted January 1, 2010 Share Posted January 1, 2010 Hi all, brother just got a 1994 disco and was trying to get the central locking to work , was checking fuses and replaced the alarm one the alarm turned on and now it wont turn of or start tryed using key in door and pod but still nothing is there any way to reset alarm or turn off completly. cheers Iain Quote Link to comment Share on other sites More sharing options...
landi41 Posted January 1, 2010 Share Posted January 1, 2010 Hi all, brother just got a 1994 disco and was trying to get the central locking to work , was checking fuses and replaced the alarm one the alarm turned on and now it wont turn of or start tryed using key in door and pod but still nothing is there any way to reset alarm or turn off completly. cheers Iain Iain, I am not familiar with UK Discos but there is a procedure to re-synchronize the alarm using the key fob....make sure you have a good battery in the fob then get yourself a copy of the RAVE CD as it relates to your brothers Discovery, RAVE contains most all the information you need to know about that Discovery. Search the Forum for where to get a copy of RAVE I was led to believe that UK alarms can be disabled but this would require Land Rover Test Book or similar software also there is/or was a UK company who would reset your alarm, sorry I can't think of their name right now but if I do i'll post it.. Good Luck Quote Link to comment Share on other sites More sharing options...
The Homba Posted January 1, 2010 Author Share Posted January 1, 2010 thanks for reply i have the rave cd and tryed what it said but it didnt work i have bypased the imobiliser to get him going but is only temp repare i have come across the "The Definitive Alarm Spider Post" in the tech archive but it says the two button remote does this also work for the one button using AMR4956 bypass plug. cheers Iain Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 2, 2010 Share Posted January 2, 2010 No - the one button should not have a spider unit. If it does, post up details, we are not infallible and may learn something! Quote Link to comment Share on other sites More sharing options...
The Homba Posted January 2, 2010 Author Share Posted January 2, 2010 hi we havent had the dash apart yet just thought it would be the same and have the spider will post up once i find out whats going on with the central locking as that has packed in too . cheers Iain Quote Link to comment Share on other sites More sharing options...
landi41 Posted January 3, 2010 Share Posted January 3, 2010 i have bypased the imobiliser to get him going cheers Iain Ian; How did you make the bypass? I'm sure this would be of interest to others, myself included. Thanks.... Quote Link to comment Share on other sites More sharing options...
landi41 Posted January 3, 2010 Share Posted January 3, 2010 we are not infallible Really? Happy New Year Stephen! Quote Link to comment Share on other sites More sharing options...
bushyboo Posted January 3, 2010 Share Posted January 3, 2010 Hi Bro finally registered im going to take the dash out today and see whats behind it will let you know how i get on Gordon Quote Link to comment Share on other sites More sharing options...
bushyboo Posted January 6, 2010 Share Posted January 6, 2010 ok have the dash off the disco taday and your right Bogmonster no spider! looks like i will have to try and get another ecu with a couple of pods Quote Link to comment Share on other sites More sharing options...
mobie Posted January 9, 2010 Share Posted January 9, 2010 Hi Have a look at this link http://www.automotiveelectronics.co.uk/ they can remove your immobiliser or reprogramme your remote, I have used them a number of times with no problems. Hope this helps Quote Link to comment Share on other sites More sharing options...
