pritch1 Posted April 20, 2006 Share Posted April 20, 2006 Well after a couple of days fitting the second hand gearbox i have now found it has a nasty clunk as i change gear. a little annoying but just one of the joys of buying second hand . So this clunk (clack) on uptake of drive is it possible to be the centre diff? it seems to be from this area? does anyone know the best way of checking this? ill have a look at the gearbox output shaft as soon as it stops raining to see if that is the problem. so any thoughts also i have heard that the centre diff is not to hard to change but what is involved? the box itself seems to be in very good condition with very good selection of gears etc so im guessing but i dont think it has covered alot of miles. sorry guessing this has been asked before but ive had a search and havent managed to find anything thanks Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 20, 2006 Share Posted April 20, 2006 What box? Quote Link to comment Share on other sites More sharing options...
pritch1 Posted April 20, 2006 Author Share Posted April 20, 2006 oh yea forgot that one its a lt77 with a lt230 transfer box it was brought as a complete unit. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 20, 2006 Share Posted April 20, 2006 Could be the splines in the output shaft going into the transfer box (pull the PTO cover off and have a look) Is the rear A frame bush OK? these make a similar noise, ans it's hard to tell where exactly the noises are really coming from as they transmit the sound right through the drivetrain. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted April 20, 2006 Share Posted April 20, 2006 Probably wear on the splines on LT77 output shaft and LT230 input gear. You can check this if you remove the PTO cover on the back of the LT230. Quote Link to comment Share on other sites More sharing options...
