clarky Posted January 3, 2010 Share Posted January 3, 2010 Since digital switch over I cannot receive any TV You can select search as usual but it does not pick up any channels As anyone else experienced similar problems? Thanks Clarky Quote Link to comment Share on other sites More sharing options...
Stopover Posted January 3, 2010 Share Posted January 3, 2010 Since digital switch over I cannot receive any TV You can select search as usual but it does not pick up any channels As anyone else experienced similar problems? Thanks Clarky Simple: Digital switchover means your old analogue tv tuner won't work. You need a digital one! Quote Link to comment Share on other sites More sharing options...
Aragorn Posted January 3, 2010 Share Posted January 3, 2010 is it a digital tuner (ie freeview)? If its just a plain old analog tuner then if the analog signal has been turned off in your area, your not going to recieve anything, as its not being broadcast any more. You might be able to install a freeview reciever if the TV system has some sort of auxiliary input. Quote Link to comment Share on other sites More sharing options...
QTdarren Posted January 5, 2010 Share Posted January 5, 2010 hi mate , pm me your vehicle details , and i will find out , im cetain there is a box of tricks , and i will also try and get you a part number and price, cheers. Quote Link to comment Share on other sites More sharing options...
Top90 Posted January 7, 2010 Share Posted January 7, 2010 Same here, I can only ever get Channel 4 now. How much is the digital upgrate if it's possible? (late 2005 Vogue) Quote Link to comment Share on other sites More sharing options...
QTdarren Posted January 7, 2010 Share Posted January 7, 2010 hope to post all details tomoz on this thread, cheers darren Quote Link to comment Share on other sites More sharing options...
QTdarren Posted January 8, 2010 Share Posted January 8, 2010 Hi guys , ok your are able to convert the old analog system using this new box of tricks , how ever its not cheap at £735.00 +vat fitting and programing is about £135.00 depending on your dearler and how quiet they are. The part number is :LRO14222 , its for petrol and diesel models up to when they were fitted with the new system, THIS WILL NOT BE COVER BY WARRENTY, if your about to buy a range rover from a dealer , check to see if it works , if it dont get them to pay for one , or the deals off, type of thing. Im not sure if you can get any thing cheaper from a radio speciltist, cheers all. Quote Link to comment Share on other sites More sharing options...
clarky Posted January 11, 2010 Author Share Posted January 11, 2010 Hi guys , ok your are able to convert the old analog system using this new box of tricks , how ever its not cheap at £735.00 +vat fitting and programing is about £135.00 depending on your dearler and how quiet they are. The part number is :LRO14222 , its for petrol and diesel models up to when they were fitted with the new system, THIS WILL NOT BE COVER BY WARRENTY, if your about to buy a range rover from a dealer , check to see if it works , if it dont get them to pay for one , or the deals off, type of thing. Im not sure if you can get any thing cheaper from a radio speciltist, cheers all. Thanks for your time and info Best regards Clarky Quote Link to comment Share on other sites More sharing options...
Top90 Posted January 11, 2010 Share Posted January 11, 2010 how ever its not cheap at £735.00 +vat fitting and programing is about £135.00 depending on your dearler and how quiet they are. Seeing as I've wanted to use it twice in over a year I think I'll make do with channel 4. Good idea about checking a new one has already been done if buying though. Thanks, Richard Quote Link to comment Share on other sites More sharing options...
