2WD Freelander
Charlies boy
Greetings to all and a Happy New Year from a new member!
This topic was last aired in 2008, so I think I am OK to revive it.
I have been running my 56reg Freestyle without propshaft for several months very successfully, even in 4 inches of snow! (of course, not quite the same performance). I was wondering if anyone has considered, or attempted going the whole way and disabling the rear diff, to further reduce drag? Before anyone asks, I have cleared running 2WD with my insurance company!
OK - I understand the theory behind doing it if it's broken... but surely a 56 reg vehicle should still have been covered by LR warranty (especially if this 'mod' was carried out several months ago) so there would be no need to disconnect the propshaft?? I'm just interested as to why it was done on such a new vehicle...besides, I thought the IRD/VCU problems were pretty much sorted by the facelift versions? :huh:
Thanks for all your comments. I have heard such a lot about gearbox problems, and how people have been running 2wd, and noticed the wind up when cornering sharply. Having discussed the whole thing with our local LR specialist we decided to give it a try, thinking that the prop could be easily be replaced anyway. Now I am so pleased with the results - free running and quicker getaway, and it irks me that the rear diff is spinning away doing nothing, and using fuel to do it (although only a tiny bit). You might say "Why not go for an ordinary car anyway?", but I like the Freelander for visibility, ride, and the seat suits my arthritic back (this is crucial).
I assume to remove the half shafts, one would have to fit short 'dummy' shafts, minus the UJs to hold the wheel bearings together?
If you really want to do it, take the driveshafts out of the outer CV's then bolt the outer CV's back in on their own. This will hold the bearings together as you describe.
You can then remove the diff, saving some weight (which is about the only valid reason for removing it at all imo)
I have to say though, not only have you reduced the vehicles capabilities, but likely affected the resale value too. I'd suggest that if you do take all these parts off, you store them all safely in the garage, so you can have them refitted when you come to sell it.
