dooroy Posted January 8, 2010 Share Posted January 8, 2010 Just fitted coils to my 2001 Td5 - now have a light on ( which I don't mind ) BUT the beeper sounds once I pass 20 mph and is very annoying to say the least . Don't want to go to main dlr as they can charge what they like - was wondering if there is any way of silencing the beeper ( cut wires etc ????). Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 8, 2010 Share Posted January 8, 2010 5 min job on a Testbook, can't cost that much surely? Quote Link to comment Share on other sites More sharing options...
dooroy Posted January 8, 2010 Author Share Posted January 8, 2010 Last year the ABS light in my brothers 300 Tdi was on following the fitting of a handsfree phone kit . Main dlr wanted €115 approx to sort it . Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 9, 2010 Share Posted January 9, 2010 Fixing a fault may be different to just resetting the configuration - it is literally a 5 min job (go into SLABS ECU setup, change suspension config from SLS to coils, clear fault codes and back out again) and I find it hard to believe anybody is going to have a minimum charge of £100? I assume the independent systems i.e. Autologic/Rovacom can do it, not sure about Nanocom as that is a lot more basic. Quote Link to comment Share on other sites More sharing options...
dooroy Posted January 9, 2010 Author Share Posted January 9, 2010 Sorry it was the SRS light that was on - not the ABS . At the time there were a number of people on the forum having the same problem - those fitting the kits sometimes tapped into the SRS system or disturbed it in some way and put the light on . Only the dealer could put it off and when I asked I was told that it was €95 + VAT just to ' plug it in ' . I told them when the problem began so I think they had a good idea it would be a quick fix. Will enquire about this as its clearcut what needs to be done ???????? Quote Link to comment Share on other sites More sharing options...
ches Posted January 9, 2010 Share Posted January 9, 2010 can be reset with nanocom. Quote Link to comment Share on other sites More sharing options...
