redben101 Posted January 10, 2010 Share Posted January 10, 2010 Having filed a pair of hub bearing washer/spacers in a safe place i need to order some new ones but i am not sure what they are. The lock tab that fits the stub axle looks like this; When i went to the part store they supplied me with this washer/spacer; Problem is that wont fit on the stub axle as the slot on the stub axle is not big enough; Am i just being a plank and have missed something very obvious? Ben Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 10, 2010 Share Posted January 10, 2010 You've been supplied the wrong part. There are two types of stub axle - one with a flat, the other with a slot, the washers are not interchangeable, or at least, the type with the flat are no good on a stub axle with a slot, as you've found. notch/slot - 217353 flat - FTC3179 Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 11, 2010 Share Posted January 11, 2010 Further to a PM from Ben, The parts in my post above are the nut lock washers. The spacer/washers, which are much thicker than the nut lock washers are tooth/notch - 217352 flat - FTC5241 Quote Link to comment Share on other sites More sharing options...
Mark90 Posted January 11, 2010 Share Posted January 11, 2010 Note there are at least two different sizes of 'flat' washer, and hence I guess spacer too. FRC8002 has a slightly smaller hole than FTC3179. Obviously the radius is the same as the bearing is the same, so it is just the position of the flat. FRC8002 will not fit on a stub axle designed for FTC3179. FTC3179 will fit on a stub axle designed for FRC8002, but may not lock as effectivly due to small amount of rotational play. Quote Link to comment Share on other sites More sharing options...
